One of my screens keeps going black randomly, playing a game, surfing the web, staring pointlessly at my desktop........ i think it could be the display port adapter but anyway to test this theory
i think it could be the display port, but i didn't have any problems when i had catalyst drivers installed but with new crimson it dose this all the time.
thoughts, concerns or am i crazy and seeing things?
https://linustechtips.com/topic/510239-common-amd-problem/
you're using a Display port to HDMI adapter i bet.
SUCH ADAPTERS MUST BE "ACTIVE" ADAPTERS TO WORK WITH AMD CARDS.
Check if it is an active adapter. If it is not. GET AN ACTIVE ADAPTER. or a Mini-display port/display port to HDMI cable.
https://linustechtips.com/topic/510239-common-amd-problem/#findComment-6803556
we've seen a lot of report of screen going black either under gaming load and even idling on the desktop with radeon cards lately on the forum...maybe there is something going on about that.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/510239-common-amd-problem/#findComment-6803559
New driver woes
https://linustechtips.com/topic/510239-common-amd-problem/#findComment-6803570
no using display-port (active) to dvi i have 4 screens hooked up only the one is doing it its prob the display port adapter bought it for cheap when tigerdrect was doing their closing sale it had a good run.... but i don't think its the problem, only sense the new drivers ive had this issue.  and it follows the screens when i change them around.
https://linustechtips.com/topic/510239-common-amd-problem/#findComment-6803588
