Hey guys, so I'm doiny my first rig (super cheap Q6600+GTX660Ti).
I have two of each Q6600 and GA-G33-S2 mobo. I want to select the best pair, so do I just swap them and bench them until I get the best result?
What should I use? Cinebench, or would you recommend anything else.
Main rig: Q6600 OCd, GTX660Ti, 4GB DDR2 Corsair Dominator RAM, 1TB WD BLUE, CX500, Bitfenix Prodigy M
Laptop: Lenovo Z50-75, AMD APU :(
https://linustechtips.com/topic/510058-choosing-between-two-same-cpus/
I don't think you would notice the difference in everyday apps tbh. But yes that would be the best result, also take the best clocker
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
Well the only real differentiation will be when it comes to overclocking.
Both motherboards northbridge will have a different tolerance and each CPU will have a different FSB/voltage scaling tolerance.
