Hello, I'm building my first PC and I'm having trouble deciding which cooler I should use for cooling my i5-6600k, my top finalists are the NZXT x61 Kraken and the THermaltake Riing RGB 360. I don't really have a budget because I'll just buy one of these two.
Thanks!
https://linustechtips.com/topic/510010-cooler-decision/
I think you will get better cooling from a triple 120mm fan radiator than a double 140mm, since it has a larger surface area (43200mm2 vs 39200mm2), plus it has pretty lights unlike the Kraken.
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/510010-cooler-decision/#findComment-6800885
