Schiit Modi 2. Pair it with Wyrd if you feel like spending another $100 on what's basically an external linear power supply for the Modi.
Don't bother trying to spend more/maxing out your budget. DACs sound more similar than different and you already have the amp and headphone bases covered.
https://linustechtips.com/topic/509741-dac-help-needed/#findComment-6797747
thank you, can I ask what audio set up you have?
https://linustechtips.com/topic/509741-dac-help-needed/#findComment-6797788
I don't know, I've never heard the 500.
The general consensus seems to be that the 560 is more technically capable, but some people still like the 500 sound better.
HE-560 sounds a bit more smoothed compared to HE-500. I feel like HE-560 is better around the midrange but HE-500 is better if you like a more sparkly treble.
As for the dac. Modi 2 Uber is probably one of the best you could get right now, optical USB and coax input in one dac. It's literally "the only DAC you ever need"
https://linustechtips.com/topic/509741-dac-help-needed/#findComment-6800594
