Confused about fan speed/performance
Solved by agent_x007,
With only 29/44C on 40% FAN's, U would need A LOT of airflow to get it moving down.
Why ?
Because with aircooling, it's all about the temperature difference between the heatsink and the air moving around it.
Try doing OCCT PSU test (or any other test that can max out heat output from GPU + CPU combo), and then compare case fan settings.
I'm guessing that U wanted to see something like this : LINK, but with idle temps.
FYI : It can't happend because of physics.
But U can try comparing 29/44C temps, to situation when U cool the air that goes into the computer with ACU.
It sould produced the result U wanted (also : no FAN settings change required ).
