Hefty, wide-base Tripod sub-$200?
Hi all,
I just picked up this teleprompter - http://www.ebay.com/itm/321217702613?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
It works great.
However, my main tripod's quick release plate can't attach to it, and the tripod I have that can attach to it can't hold it very well, the whole rig almost fell in the floor.
I need to stand in front of the tripod, and I'm quite tall, so I've been using this tripod, but like I said, the screw in the quick release plate isn't tall enough to screw into it, and it's a POS plate anyway. But when I was shopping Amazon for other 75" tripods, they all looked the exact same/looked like they had the same plate.
So I switched to an older, but more durable, Sony tripod I have, but it's a lot shorter, so I had to extend the middle pole up a lot. Left it there all day and it was fine, but then when I hit record (adding movement) the whole plate flipped out.
So I need a tripod that has a sturdy attachment base. Either a large/wide plate system, or one that I can attach my own tripod head to, that could support the weight of that prompter + DSLR + tablet. But I don't exactly have the ability to spend a TON on it. And I need it to get close to my 6'2" height, or things are going to look bad.
Any ideas?
Thanks guys, as always.
i use this tripod with a manfrotto 502ah fluidhead http://www.amazon.com/AmazonBasics-67-Inch-Video-Camera-Tripod/dp/B00CEH7VG8/ref=sr_1_1?ie=UTF8&qid=1450564840&sr=8-1&keywords=amazon+basics+video+tripod
It is built like a tank. The main trade off with that tripod is the weight. While its built very well, its HEAVY. The video head on it is also fairly mediocer. Good if you are not wanting to pan or tilt with video though.
