Hello, just finding a cpu cooler for my i5 6600k, I'm using the Enthoo Pro as my case and I was planning on overclocking. What would be a good cpu cooler?
NH-D15. It's the best cooler on the market without doing a custom loop. What's your price range?
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
https://linustechtips.com/topic/508653-enthoo-pro-stuff/#findComment-6785325
I don't really have one, though I was looking at some: NZXT x61 and the H110i GTX, which is better?
They both have their pros and cons. I prefer the aesthetics of the Corsair, as well as the build quality. However, the x61 typically has an edge in performance, and I certainly prefer NZXT's software.
https://linustechtips.com/topic/508653-enthoo-pro-stuff/#findComment-6786732
The Kraken cools better and is quieter.
The x61 cools better but its far from being quieter.
http://www.silentpcreview.com/article1408-page6.html
Not sure--they seem similar. http://www.tweaktown.com/reviews/7320/corsair-hydro-h110i-gtx-high-performance-liquid-cpu-cooler-review/index7.html
I don't know why you're spending so much for a cooler on an i5 though. You're better off going with a cheaper cooler and the i7.
https://linustechtips.com/topic/508653-enthoo-pro-stuff/#findComment-6787001
The Enthoo Pro is quite a wide case, so you definitely shouldn't rule out an air cooler. The top end air coolers should have you covered for any overclock to around 4.7GHz, depending on your draw of the silicon lottery. The NH-D15 is a great cooler, most people don't like how it looks, but the mounting hardware is awesome. The bequiet! Dark Rock Pro 3 isn't as good, but it looks better and the mounting hardware sucks. The Cryorig R1 Ultimate looks good, performs close to the NH-D15, and has good mounting hardware.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/508653-enthoo-pro-stuff/#findComment-6787078
With recent reports of 6gen chips bending while using air coolers, I'm somewhat weary of using some of the monster coolers.
https://linustechtips.com/topic/508653-enthoo-pro-stuff/#findComment-6787280
