Monitor mount
ShoMy
Go to solution Solved by UL_42L,
Here, this might help.
 Does anyone has Asus VH228 monitor wall mounted?
How did you mount it?
Google searching provided nothing even remotely referencing it, so unless someone here knows something I don't, you're SOL.
Thy hath sinneth, and in thy life thou hast fallen to an unholy, unspeakable level of humanity. Thou hast given into your basest needs. And suffered many years under thine Satan-box. However, if thine be willing, as thy hast show yourself to be, thy can ascendeth into thy glorious fold of the glorious church. Go well, my brother, may your temps be low and your frames high. ~ MrDynamicMan
It has a 100x100mm VESA mount on the back if thats what you mean.
My Build: Phoenix
Processor: Intel i7 4770k, Motherboard: Asus Z97-P RAM: Corsair Dominator Platinum 16GB GPU: MSI GTX 1050TI OC Case: Corsair ICUE 4000X, Storage: Samsung 840 EVO 120GB + 500GB + 2TB HDD PSU: Corsair RM750, Cooling: Corsair H100i Capellix,
        If you want to talk to me or give me an answer, please tag me otherwise you'll be talking to thin air ❤️
*Insert jerry-rigging here.*
[spoiler=Current Rig] N/A
