Yes, you power supply has 2x 8pin (6+2 pin) pci-e power cables, so it will be fine for most newer cards.
You wont be able to crossfire, or sli, because there are only 2 cables, but going from the name, it wont have enough wattage to power 2 graphics cards anyways.
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/508557-small-question/#findComment-6784354
aw
AWESOME NEWS!
https://linustechtips.com/topic/508557-small-question/#findComment-6784361
PSU: Cooler Master B500
GPU: R9 Fury sapphire tri-x
CPU: i5 4460
Does my GPU have all connectors to power on my GPU?
HOLY SHIT please do not pair a Cooler Master B-series with a Fury!!!! That's a very bad idea, like pairing a Titan Z with an EVGA W1. Get yourself a new PSU pronto.
https://linustechtips.com/topic/508557-small-question/#findComment-6785079
