I might just be overacting here but I'm experiencing the same thing this guy is experiencing (https://www.youtube.com/watch?v=ifieDriw9_k) Only happens when I'm playing a game so I think it's my GPU (evga gtx 970). Is this a coil whine or what and should I be worried? Would a coil whine this minimal be covered under warranty?
https://linustechtips.com/topic/508380-gpu-buzzing-sound/
Most definitely coil whine, and it really depends on the company although it's usually not covered (But if you bought it recently, I would return it and buy a new one)
// irenebb-pc v5 // [] Intel i5-9400F [] Radeon VII Lisa Su Edition [] 24GB Crucial Ballistix [] Acer ED323QUR (1440p/144hz) []
https://linustechtips.com/topic/508380-gpu-buzzing-sound/#findComment-6782431
just coil whine thats all . completely normal if your worried.
happens on my msi gaming 4g gtx 970
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/508380-gpu-buzzing-sound/#findComment-6782432
GPU is almost 9 months old. Still has the 3 year warranty that it came with though. Saw this article though, I don't know how reliable it is. But in it EVGA stated this - "We have been watching the early feedback on GTX 970 and inductor noise very closely, and have actively taken steps to improve this. We urge anyone who has this type of concern to contact our support so we can address it directly."
https://linustechtips.com/topic/508380-gpu-buzzing-sound/#findComment-6782440
tbf yours was so minor it wouldnt be worth rmaing.. you will probably get another card with coil whine.. it happens on all 970's
https://linustechtips.com/topic/508380-gpu-buzzing-sound/#findComment-6782456
That's waht I was thinking of as well.. Might as well wait it out and see if it disappears then. What are the odds of that happening though LOL?
https://linustechtips.com/topic/508380-gpu-buzzing-sound/#findComment-6782484
