I have:
- EVGA 500W power supply.
- Samsung evo 850 250Gb ssd and a 1tb hdd
MSI NVIDIA GeForce GTX 970 GAMING 4G 4GB 256-Bit GDDR5 Graphics Card
(and periferals)
what else should I get that will give me the best bang for my buck? I have 450$ left for cpu, motherboard and ram. I would like 16 gigs of ram (8 & 8) with a possibility to get 16 more later. (so I guess I'll need a motherboard with 4 ram sockets)
https://linustechtips.com/topic/508306-help-building-my-first-gaming-pc/
I have:
(and periferals)
What's your total budget?  I can do much better.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
duuuuuude $450 for a mobo, cpu and more. My CPU is $500, although you wont need that. Looking at what you got, you could get a GTX 960 instead, get a 1TB hard drive and just a 120gb ssd. save atleast $150-200 for mobo. Look at a high end i5 or med-high i7 chip
he already has a 970, he wouldnt spend the money on a 960 and downgrade.
I have:
(and periferals)
check out this build i did for a friend http://pcpartpicker.com/p/w2grFT, look into the CPU and RAM. It would come to like $500, in which case you could get the same motherboard and RAM but just get an i5-4690k to save money which will be fine.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
I thought he was saying that he was planning to buy those and those were the things he had already planned to buy. Because I was saying instead of buying the 970, buy a 960 and save the money for something else.
I have:
(and periferals)
when I said I have it is because I have it.
Try to find a way to increase your budget by $100 more. If you really can't, you might have to get a weaker ram and a cheaper z97.
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Total: $549.95
Generated by PCPartPicker 2015-12-19 00:08 EST-0500
