Driver help
Solved by KraftDinner,
I am using a GA-F2A88X-D3H and I don't know if I need the raid driver. Also, if I'm using the sound driver from realtek (directly from their website and not from gigabyte) I should be fine, right?
No you won't need it unless you're running a RAID configuration. The sound drivers should also be fine
kerriya ·
Posted in Cases and Mods0 -
octester ·
Posted in Troubleshooting3 -
DavidPatrascu ·
Posted in General Discussion5 -
2
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
play_circle_filled
Latest From ShortCircuit:
