Does specific power cable matter?
I will be returning my monitor.
I am concerned I might return the wrong power cable. I have a few f these 3 hole/pin power cables (the same power cable connectors that come with your PSU). Does it matter if I return the wrong one?
They all say they provide 10A and 250V but could one be providing less stable power? Is this something I need to worry about? If so, I would need to make sure I return the exact same cable that came with my Asus VE247 which would make it slightly harder for me/ take more time.
If anyone has this monitor, could you send me a close up pic of what the plug which connects to the monitor looks like, please?
https://linustechtips.com/topic/508179-does-specific-power-cable-matter/
They will all work but in general since it's not a high current device but for high wattage PSU's the larger wire diameter (smaller AWG number) is good for the extra current carrying capacity.
no shouldnt be a problem... unless it doesnt actually power the monitor on or fit.. if it has specific labeling on the cord then I would find it but generally they are all the same.
We're all dying slowly
Pentium G3258 3.2 ghz / ECS z97 pk MOBO / Intel Stock Cooler / R9 290 DD / Corsair Carbide Air 240 / 4GB mushkin stealth ram at 1600 / XFX 650W 80+ gold PSU / Kingston v300 240GB drive W/300GB seagate drive / HP x2301 / Gateway KB / Monoprice GM
