V12XT fan controller.
Trickster
I just got my Fan controller, and I was wondering, can I hook my water cooling pump upto it? Or would that be a bad idea, my specs are in my sig.
Thanks!
Update coming soon.......... ;)
It's connect to the 4 pin. And this fan controller has a 4 pin too. And I'm just making sure it would work still, if I was to plug It I to the fan controller. :).
And how do I put a sensor onto the CPU? As its water cooled...
Ok, i have it all plugged in, but i can't change the speed of my fans? Why is this? :(
