Hey, guys, im trying to build a storage pc for my unce on a budget of $450. it doesnt need to be powerful at all, just needs to have plenty of QUALITY storage.i already have ram, so no need to add. heres what i have.
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard  ($67.99 @ SuperBiiz)
Case: Cooler Master N200 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic 300W 80+ Bronze Certified ATX Power Supply  ($35.99 @ SuperBiiz)
Total: $445.96
Generated by PCPartPicker 2015-12-17 16:53 EST-0500
what do you guys think?
ps. most important is QUALITY
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/507434-450-storage-pc-build/
Interesting, reliable PSU, nice board, and I think the CPU is more than enough.
yeah, i wanted quality above all. thisi is just a basic pc to store security footage for his bar
6 TB should be enough for days of footage at 360p~480p 24  FPS
Rigs I've Built
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772082
You'll still have issues if that drive breaks, you will still need another backup ( with every setup even raid )
I would recommend a HGST drive ( if the files are important ) they have lower failure rates but cost more.
http://www.amazon.com/HGST-Deskstar-3-5-Inch-Internal-0S03839/dp/B00O0M5QK8/ref=sr_1_1?ie=UTF8&qid=1450389561&sr=8-1&keywords=HGST+6TB
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772085
sorry but i love the reliability of WD RED pros, cause of the long warranty. the files on the drive arent completely MISSION CRITICAL so i might stay with WD but i will look into hgst, thank you!
Rigs I've Built
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772115
Get an H81 board, H97 is overkill for this build, I recommend the MSI H81M-E34. It's a great board
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772118
CPU: AMD A4-7300 3.8GHz Dual-Core Processor  ($39.99 @ NCIX US)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  ($47.98 @ Newegg)
Total: $402.95
Generated by PCPartPicker 2015-12-17 17:03 EST-0500
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772132
They still have an 6% annual failure rate in a datacenter environment according to blackblaze: https://www.backblaze.com/blog/hard-drive-reliability-q3-2015/
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772142
Well what you'll want is HGST drives
and you should really be going for ECC memory, if not get an AM1 build due to how low cost and low power the chips are
the case supposedly supports 3 3.5" drives and the motherboard supports up to 4 drives natively, spend the extra money on a battery back up
PCPartPicker part list: http://pcpartpicker.com/p/rzB6GX
Price breakdown by merchant: http://pcpartpicker.com/p/rzB6GX/by_merchant/
CPU: AMD 5350 2.05Ghz Quad-Core Processor  ($49.98 @ Newegg)
Motherboard: ASRock AM1B-ITX Mini ITX AM1 Motherboard  ($34.99 @ Micro Center)
Memory: Crucial 8GB (1 x 8GB) DDR3-1600 Memory  ($34.97 @ OutletPC)
Storage: Hitachi Deskstar NAS 4TB 3.5" 7200RPM Internal Hard Drive  ($159.99 @ B&H)
Case: Cooler Master Elite 110 Mini ITX Tower Case  ($39.99 @ Newegg)
Total: $347.91
Generated by PCPartPicker 2015-12-17 17:13 EST-0500
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772165
as i said in the msg above, its not a  mission critical system, its just going to hold security camera footage. ill get HGST but ecc memory is overkill
Rigs I've Built
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772226
Ah well they make drives specifically for that, not sure on what the advantage is though. cost is the same as the drive in that build already, ECC is important for data integrity overall, and there's an AM1 board that maybe supports it, but, ya I dunno
http://www.amazon.com/Purple-Surveillance-Hard-Disk-Drive/dp/B00IMPO5OW
http://www.wdc.com/en/products/products.aspx?id=1210
There's also this for an idea on software
https://linustechtips.com/topic/507434-450-storage-pc-build/#findComment-6772250
