First Build
Go to solution Solved by GodSpoon,
750ti costs double the GT730..
I really don't want to play them all, just want to play casually / try them out.. But will definitely upgrade my RAM.. :)
If your just casually gaming, 4GB is just fine
If you want a good price on a 750, EVGA has B stock
https://www.evga.com/Products/Product.aspx?pn=01G-P4-2753-RX
Hi! Just assembled with my first build. I just bought the parts without knowing how efficient would it be.
Now, I'm planning to replace my video card so that I can play recently released games.
Current Build:
CPU: i3 3240 3.4Ghz
Motherboard: Alienware x51 itx
RAM: 2x2gb Apotop 1600mhz
Video Card: AMD HD 5450 64bit
PSU: 600watts Vortex
Case: Thermaltake Core v1
Now, I'm wondering if I could replace my HD5450 with GT730 1gb 64bit ddr5 since I'm on a tight budget. Would it
be a bottleneck build? Or should I push through 750ti? Thanks!
https://linustechtips.com/topic/507405-first-build/
Current Build:
CPU: i3 3240 3.4Ghz
What do you consider a TIGHT BUDGET?
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
https://linustechtips.com/topic/507405-first-build/#findComment-6771605
Current Build:
CPU: i3 3240 3.4Ghz
Definitely don't get anything worse than a 750ti if your expecting to play newer titles
If you can afford it get a 950
https://linustechtips.com/topic/507405-first-build/#findComment-6771609
4 gb of ram is not enough for gaming
Intel Core i5 4590Gigabyte GA-970 Ax4 4GB DDR3 Crucial Balistix SportGigabyte Windforce GTX 970 | 3 TB of HDD | Enermax CoenusEVGA 500 Watt 80 Plus | Windows 10 | Razer Black Widow Tournament EditionLogitech G502 Proteus Core | Audio Technica M50x | Tonor BM 700 Nikon D3400
CompTIA A+ Certified
https://linustechtips.com/topic/507405-first-build/#findComment-6771666
https://linustechtips.com/topic/507405-first-build/#findComment-6771718
https://linustechtips.com/topic/507405-first-build/#findComment-6771775
Oh! that's a lot cheaper than 750ti.. Will try to ask our local stores for it. Thanks!
EDIT:
OMG! I don't think we have b-stock products here locally.. But thanks anyways.. :)
Just wanted to know, either 730 or 750ti.. it won't be a bottleneck, right?
https://linustechtips.com/topic/507405-first-build/#findComment-6771804
