Connecting COAX
Woops, my fault. Something went wrong.
Anyway, the first picture is where the signal comes into the house, the cable that is missing a connector is going upstairs to my room. The other picture is the box where the cable from downstairs comes out. (The connected one is useless and isn't going anywhere) Can i connect the modem on the box in the second picture? Internet won't be 150 mbps, It will be limited to 40 mbps due to distance to the local exchange. BTW don't mind that nut, my cats are throwing those around the house the whole day. And i'm to lazy to pick them up.
You'll need to re-terminate the top cable of course. You'll also need to install a splitter - connect the incoming line to the splitter, then the splitter to the two outgoing cables (To your room and to the living room).
This will allow the living room to still be able to connect to Cable TV (either direct jack, or via a Cable Box, depending on what your Cable TV service supports - most modern Cable TV services require the Cable Box these days it seems). Then you can connect the Modem to the jack in your room.
It's very important to only connect ONE modem though (Eg: Don't also put one in the living room).
