Difference between PATA and IDE
Solved by Captain_WD,
~snip~
Hey there AlphaGamer46
IDE or Integrated Drive Electronics is the original name. After that it was renamed to the ATA standard or Advanced Technology Attachment which included additional features such as CD-ROM connectivity and others. When the Serial ATA or as we know it today SATA came out the old standard became PATA or Parallel ATA. ATA can refer both to SATA and PATA so the P was added to make things more clear and avoid confusion.
Since IDE was renamed to ATA you may say that both PATA and SATA are IDE-types
Feel free to ask if you need more info
Captain_WD.
