Guys I need some advice. I have an r9 290 reference card and its running quite hot. I have a cpu aio water cooler, but i dont want to remove the heatsink. do u guys think it would be a good idea to place the cooler on the back side of the gpu die so it will at least help dissipate the heat away? will there be a short on the gpu if i do so? im planning to mount the cooler on the gpu die mini backplate. thanks in advance.
https://linustechtips.com/topic/506373-help-pls/
the cooler block is made of copper or polished aluminum and it conductive
do not put any conductive items on the back of the GPU die
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/506373-help-pls/#findComment-6758774
Do not do this, you could very easily short out components on the back of the GPU.
-snip-
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
https://linustechtips.com/topic/506373-help-pls/#findComment-6760626
