Hi, can anybody tell me if this case supports a Corsair H110i GT as it is a 280mm AiO and I can't find specs anywhere. The case is the Phanteks Enthoo EVOLV ITX, thanks :D
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
https://linustechtips.com/topic/506111-max-compatible-aio-in-this-case/
looks like it should fit in the top. The front is questionable for radiators bigger than a 120.
Current: R2600X@4.0GHz\\ Corsair Air 280x \\ RTX 2070 \\ 16GB DDR3 2666 \\ 1KW EVGA Supernova\\ Asus B450 TUF
Old Systems: A6 5200 APU -- A10 7800K + HD6670 -- FX 9370 + 2X R9 290 -- G3258 + R9 280 -- 4690K + RX480
yes it will fit
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
Okay, yes I was looking to mount the 280 in the top?
http://asiat.co.uk/
http://hndrx.co.uk/
