I repair and build computers and I've seemed to notice a trend of NEVER having the right screws for one thing or another and I can't seem to find a full kit with everything I need. I need: Motherboard screws, Motherboard stand off screws (long and short), Fan/Radiator screws (long and short), HDD/SSD screws, 5.25" bay screws. The whole nine yards basically, the bigger and more comprehensive the kit is the better but, those are the main screws I absolutely need.
I apologize if this is posted in the wrong area, couldn't think of a better place.
https://linustechtips.com/topic/506085-need-a-comprehensive-screw-kit/
When in doubt, re-format.
Really? After my first build I was already stocked up, and after a couple years I have tons of every screw you could ever dream of.
Would be interested to see what kits get recommended.
"Epic Voice, Quality Content"
I googled it as well but couldn't find what I was looking for, thanks for the recommendation I'll take a peek at it and see if it has everything I need.
EDIT: took a look at it, really only thing that it's missing is fan screws, I need your standard fan screws and also ones that will go through 30 and 45mm thick rads and the fans which are 25mm
Well most of the work I do is adding HDD/SSD's and/or something into a 5.25" bay so the stock that I DID have has slowly eroded away to nothing over the years and I've started robbing screws out of things I shouldn't be taking screws out of, namely my own rig.
