Hi guys:
I'm looking for parts for my new build.
I'll sell my "old" rig because i stop play very demanding games etc.. for about 900-1400€
you can find it below.
For that budget i want to build a new Workstation and buy a new monitor, pretty much the same that i already have for round 350€
So there are 700€ left for my new pc:
Most likely i'll use it for
Office work, Medienstream in the network, dreamweaver photoshop visualstudio etc
It should be silent and small
thanks for your help
Ivan
 Rig:
350€ 29" (73,66cm) LG Electronics Flatron 29EB73-P schwarz 2560x1080 2xHDMI 1.3/1xDVI/1xDP
not going to sell the monitor
330€ Intel Xeon E3-1231v3
130€ 16GB (2x 8192MB) Crucial Ballistix Sport DDR3-1600
320€ 4096MB Palit GeForce GTX 970 JetStream
25€   EKL Alpenföhn Brocken ECO Tower Kühler
70€   MSI H97 PC Mate Intel H97
60€   500 Watt be quiet! Pure Power L8 Non-Modular 80+ Bronze
1350€ mit Extras
post-198255-0-06162300-1450201255_thumb.
https://linustechtips.com/topic/505983-workstation-build/
What country are you in?
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/505983-workstation-build/#findComment-6753614
Is your GPU sagging that much, or is it just me?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/505983-workstation-build/#findComment-6753665
Hi guys:
Why don't you just buy a cheaper GPU and sell the 970?
You aren't going to get a better CPU than a Xeon 1231v3 at that price point I don't think, a 5820k is like 400 EU on the german part picker
https://linustechtips.com/topic/505983-workstation-build/#findComment-6754275
Because i dont rly need a 1231 rather a top tier i3 or i3 skylake
at thats what i was thinking
So im going to waste 60 € for a gpu that has the same performance as the IGU?
+ im want a smaller system for lans
https://linustechtips.com/topic/505983-workstation-build/#findComment-6754693
CPU: Intel Core i3-6320  ($171.98 @ Newegg)
Motherboard: ASRock H170M Pro4  ($94.99 @ Newegg)
Memory: ADATA 16GB (2 x 8GB) XPG Z1  ($68.99 @ Newegg)
Power Supply: Antec 400W High Current Gamer Series HCG-400  ($0 - Unavailable)
Storage: SAMSUNG 250GB 850 EVO MZ-75E250B/AM  ($79.99 @ NCIX)
Case: AeroCool DS-Cube White  ($101.52 @ Mwave)
CPU Cooler: COOLER MASTER Hyper TX3 RR-910-HTX3-G1  ($18.75 @ Amazon)
Total: $536.22
https://linustechtips.com/topic/505983-workstation-build/#findComment-6757219
Am i
You're going to be using the iGPU only? If you want something truly small look for the mini-box cases or some In win cases, not sure on their availability in your area
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108416
and are you sure you're giving up on gaming overall? because there are some 65W TDP APUs out there that can still game well without a GPU
if you wanna just downgrade that's fine but like I don't see too much reason to go with the i3 over like a laptop that has an i7 in it for productivity
or possibly look for a NUC, this one has an i5
http://www.amazon.com/Intel-NUC5i5RYH-Processor-2-5-Inch-Support/dp/B00SD9IS1S/ref=sr_1_1?s=pc&ie=UTF8&qid=1450236550&sr=1-1&keywords=NUC
https://linustechtips.com/topic/505983-workstation-build/#findComment-6758541
