Does anyone know if this 4k HMDI cable will be suitable for my monitor and graphics card? I am using Dell U2515H monitor and Asus Gtx 980 ti Strix graphics card. Will it allow be to run on 1440p and on 60hz?
Here is the link to the cable :http://www.valore.sg/Valore/project/valore-flat-4k-hdmi-cable-1-8m3m-v-av1070/
https://linustechtips.com/topic/505656-4k-hdmi-cable/
1440 yes
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6748883
Most likely. I recommend display cable tho
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6748886
meanwhile i'm pushing 1600p over one of these:
something i should note tho, i had a cable like that, my dad ripped it apart when "carefully" turning the TV.
the connectors arent actually made of metal, the metal is just a glued on decal.
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6748900
That monitor is supplied with a mini DP to DP cable.
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6749015
The mini DP is usable as well? As long as I have a DP cable?
Not sure if I'm understanding correctly, but one end is male mini DP and the other end is male DP.
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6749657
You don't need a DP cable, the monitor includes one.
Oops sorry I misunderstood u guys. The mini DP to DP cable provided inside can run on 1440p n 60hz too? Sorry, I'm pretty new to this as this is my first build
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6749808
Yes, absolutely.
https://linustechtips.com/topic/505656-4k-hdmi-cable/#findComment-6749841
