Hi, I have a  MSI AMD Radeon hd 7770 2gb and i cleaned out some dust yesterday and all of a sudden in csgo my frames go from 300 (which is what i usually get to around 60 almost 2 times per sec and I dont know if something broke or its because I broke my mouse, but thats unlikely because it broke after this happened. So any help would be appreciated.
https://linustechtips.com/topic/504895-major-problem-with-graphics-card/
How did you clean the dust out? System specs?
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
Can you monitor your thermals whilst playing? If you removed the cooler without replacing the thermal paste your card might be overheating and thermal throttling. We need more information though, what are your specs? If you can, post screenshots of thermals and CPU, RAM, GPU and VRAM usages whilst playing
i7-7700 | Asrock H270M-ITX | Fractal Design Core 500 | 16GB Corsair Vengeance LPX | EVGA GTX 1080 Ti | 850 EVO 500GB | 850 EVO 250GB | WD CavGreen 2TB
EVGA SuperNOVA 550W | Steel Series Elite Prism | Final mouse 2015 | WASD Keyboards V2 (MX Blue) | Acer Predator 1440p 144Hz
CPU AMD FX-8350 Eight-Core Processor
GPU AMD Radeon HD 7700 Series
6 gigs of DDR3 Hyperx
MOBO GIGABYTE GA-970A-D3P AM3+/AM3  AMD 970 6 x SATA  6Gb/s USB 3.0 ATX  AMD Motherboard (found it :3)
Temps are constant 40C-45C at 30 fan speed
I cleaned the dust out with an air can and flipped my PSU around so the fan was upward to prevent more dust buildup.
I also cable managed a bit.
post-293785-0-45417700-1450052503_thumb.
