So after 3-4 days of inactivity, i started my pc and within 2 min after booting i noticed the fans speeding up to maximum (i had only chrome open) so i panicked and restarted the pc, and it showed me CPU over temperature error, went to bios and CPU Temp was 80-84C, so i removed the cooling block, clean the thermal paste, i apply new one and i boot it up again and again in the bios the temperature of the cpu was rising fast to 80C, after a while a booted up windows again and in the task manager i saw 90-95% CPU usage (keep in mind i didnt open anything i was only on the descktop with task manager) so in processing the app that took most of the cpu was somerhing like " System idle process "
Has anyone experienced this before or can anyone suggest some fix or something about this?
My hardware specs:
Cpu i7 5820
Cooling H100i
Mobo x99 deluxe
I thing thats enough
I didnt put this into water cooling section cuz the fans seems to work fine (and loud) and the LED is working but its channging colors witch is unusual cuz usually it stays green.. So maybe the problem is something around the cooling?
But than why is the CPU showing 90% usage.
This post became too long (sorry)
And no im not overclocking. Eveything is at default.
https://linustechtips.com/topic/504096-cpu-overheating-problem/
Pump most likely died. This is why I prefer air coolers.聽
CPU:I7 4790k聽聽CPU Cooler: NH-D15聽GPU:聽MSI 970 4gb聽 聽Motherboard: z97 Gaming 5PSU: Corsair hx850聽聽Ram:Corsair Vengeance 8 gb聽聽SSD: Samsung 850 Evo聽聽Case:Air 540
https://linustechtips.com/topic/504096-cpu-overheating-problem/#findComment-6729669
I tried linux and safe mode as u said with out cpu load, i couldnt monitor the temperature but i could hear the fans speeding up to maximum again.. :/
Why would the pump die? Ive been using this build litle over a year now, no overclocking no nothing out of the ordinary...
https://linustechtips.com/topic/504096-cpu-overheating-problem/#findComment-6729715
Sometimes they do just die. If you've not had it long, you can RMA your H100i without too much of a problem. If you want an air cooler instead, the Noctua NH-D15 is worth a look if you don't mind the colour of the fans.
#NoctuaNH-D15MasterRace <3
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz聽|聽PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB |聽Case | Cooler Master MasterCase Pro 5聽| CPU Cooler聽| Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz聽| PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy.聽http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/504096-cpu-overheating-problem/#findComment-6729838
Well while we are discussing alternatives for the cooling is hyper 212 evo an option? While i wait for the RMA or maybe for long term?
The hyper 212 is decent. It won't be able to handle extreme overclocks but it can easily handle moderate overclocks. It depends on how far you want to push your cpu.
30.00 to keep using your system while you rma your cooler is a reasonable price I'd say, especially since you'll have a decent back up cooler for future issues if they occur
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v)聽COOLER: NZXT Kraken X61聽MOBO: Asus Z97-A 聽 RAM: 16GB Crucial Ballistix Tactical 聽聽GPU: EVGA GTX 970 SSC 聽 PSU: EVGA GS 650W聽 聽CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/504096-cpu-overheating-problem/#findComment-6730600
YESH
https://linustechtips.com/topic/504096-cpu-overheating-problem/#findComment-6739664
