So none of my games are working, i`m playing them at 20fps (this has happened a while ago) yesterday i was playing with 60 , now every game runs at 20 fps , last time i rolled back my driver and everything worked but now i can't roll it back ,any idea how can i roll it back?
https://gyazo.com/fa577f7d88735ab33646983031fbd783
E: Should i uninstall it and install it again?
https://linustechtips.com/topic/503842-fps-problems-in-games/
What GPU? What specs? What games?
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/503842-fps-problems-in-games/#findComment-6726520
and your gpu and cpu is...?
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/503842-fps-problems-in-games/#findComment-6726538
Bad GPU , but doesnt matter , yesterday was working ok , with 60 fps in games (GTX 745 4GB) , and like i said it happened a while ago but solved it by rolling back .
Games ? any game.. Vindictus , Skyrim , CSGO , BNS , everything.
Specs:
CPU: i7 4790S 3.2ghz
GPU: nvidia GTX 745 4GB
Ram: 16 GB
https://linustechtips.com/topic/503842-fps-problems-in-games/#findComment-6726542
it could be throttling? temps under load? check with hw monitor or msi afterburner OSD
https://linustechtips.com/topic/503842-fps-problems-in-games/#findComment-6726546
This is when i start a game > https://gyazo.com/1e43c393294f9674298a1d97781885f0   max temp is 65*C
Where can i find the previous version of nvidia drivers?
EDIT: MSI afterburner stress test https://gyazo.com/abe50b90e933990f159fc44b4508f40c Shouldnt my GPU use like 2gb of ram ? why only 300mb
EDIT2: i`m downloading an older driver version , i`ll post back the results.
https://linustechtips.com/topic/503842-fps-problems-in-games/#findComment-6726559
