Coolant for Predator 240
Solved by W-L,
Is distilled water ok? Or should I buy a certain coolant?
I assume for expanding that loop ![]()
Yes you can use distilled fluid but you need a biocide like PT Nuke or Mayhem biocide, alternatively you can get premixed fluids which are also great.
Serendipity1344 ·
Posted in Graphics Cards3 -
1
1
5
1
toxic_worper ·
13
1
voltigeurramon ·
Posted in Troubleshooting2 -
2
