Graphics card issues
Go to solution Solved by SirDucksallot,
Well,usually,when that happened to me,I just resseted with the normal way(Start->Reset) and it fixed itself.In that case,try a driver reinstall(w/o OC).
So I recently started overclocking my msi gtx 970 with msi afterburner and I pushed it until it became unstable without adding voltage when it became unstable I rebooted my computer using the power button as I wasn't getting an image. When I log back in it says that the driver had stopped working but successfully recovered but when I loaded up valley my core clock would only go to 540mhz and that was it. So I did a proper shut down of the system logged back in and the same issue so I left it off overnight and it would boost fine but when I started again the same thing happened and it wouldn't boost again I don't know wether it gets stuck in safe mode or what please help.
Any help appreciated
Thanks
https://linustechtips.com/topic/503273-graphics-card-issues/
Shark Rampage V: AMD FX-4350 @ 4.5GHz(1.404 Volts) / Hyper 212 Evo / Gigabyte 750Ti (1405MHz Core,3200MHz Memory @ stock voltage) / Kington HyperX Fury 8 Gigs 1866MHz Dual channel / ASUS M5A97 R2.0 / WD Caviar Blue 1TB 7200 RPM / 850Evo 250GB / XFX TS 550w 80+ Bronze Sharkoon VG4-W
https://linustechtips.com/topic/503273-graphics-card-issues/#findComment-6721372
Sound suggestion.... I honestly have never had gpu overclocking problems with my card but i have a AMD card so my drivers and settings are probably different.
"I take great pride in my humility" -Me
My Steam Profile (from SteamDB)
  • Worth: $1614 ($629 with sales)
  • Games owned: 126
  • Games played: 111 (88%)
  • Hours on record: 3,483.3h
https://linustechtips.com/topic/503273-graphics-card-issues/#findComment-6724256
