This is my first computer build and I am trying to figure out if all the parts are compatible and wont have any kind of issues.
Motherboard: Asus Z97 - A USB 3.1
CPU: Intel Core i7 - 4790K
Fan: CM Hyper 212 EVO Cooler
Graphics Card: PNY GeForce GTX 960 4GB
RAM: Vengeance 16GB DDR3 1600MHz Dual
Power Supply: Corsair CX850M
Solid State Drive: 250GB Samsung 850Evo S
Hard Drive: Western Digital 1TB
OS: Windows 10
Disc Drive: LG OEM DVDRW 24x Int
Case: Enermax Coenus Gray ATX
https://linustechtips.com/topic/502982-my-first-build/
Welcome to the fine community of the Linus Tech Tips Forum sir. I suggest following your topics so that you get notified when someone replies! Also PCpartpicker is a great place to store all your builds! I may be a little biased but I would go with an r9 280x or even a 390 if you have the budget! What WD drive is it? (blue, black red, ect.)
https://linustechtips.com/topic/502982-my-first-build/#findComment-6715856
What are you planning to use it for?
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/502982-my-first-build/#findComment-6715862
if gaming id swap the i7 to a skylake i5 build and swap out the 960 to an AMD 390
Ryzen Ram Guide
My Project Logs   Iced Blood    Temporal Snow    Temporal Snow Ryzen Refresh
CPU - Ryzen 1700 @ 4Ghz  Motherboard - Gigabyte AX370 Aorus Gaming 5   Ram - 16Gb GSkill Trident Z RGB 3200  GPU - Palit 1080GTX Gamerock Premium  Storage - Samsung XP941 256GB, Crucial MX300 525GB, Seagate Barracuda 1TB   PSU - Fractal Design Newton R3 1000W  Case - INWIN 303 White Display - Asus PG278Q Gsync 144hz 1440P
https://linustechtips.com/topic/502982-my-first-build/#findComment-6715946
All looks good but I'd chuck a bit more money at a better PSU
CPU: i7 4790k 4.6GHz @ 1.19v     GPU: Gigabyte G1 GTX970 1590Core     RAM:16GB Corsair Vengeance Pro    SSD: Samsung 850 Evo Raid 0
Cooler: Corsair H110i GT             Case: NZXT H440 Black Windowed          1TB WDD Blue, NZXT Hue+, MSI Z97S SLI Krait, Asus VX347H x2
https://linustechtips.com/topic/502982-my-first-build/#findComment-6716269
get a better cpu, cx are meant for everyday office/home use, not gaming/overclocking
also get a 380/380x for the price, or cut down to an i5/r9 390 combo
psu good for the money:
seasonic m12ii/s12ii/G/s12g, xfx ts/xtr, evga b2/g2/gs/gq/p2/ps, antec hcg/hc pro/edge , corsair RMi/RMx (not normal RM)/Hx/Ax, coolermaster VS/VSM, superflower leadex gold/platinum
The site has changed....
https://linustechtips.com/topic/502982-my-first-build/#findComment-6717166
The reason I didn't choose a better cpu is because I checked on the asus website to see what is compatible with the motherboard and the i7 4790K was one of the best. So if there is another motherboard around the price of $160 that someone could suggest for me that would be great.
https://linustechtips.com/topic/502982-my-first-build/#findComment-6721367
yes that is a great combo, don't forget to switch the ram to DDR4
Ryzen Ram Guide
https://linustechtips.com/topic/502982-my-first-build/#findComment-6722231
an AIO cooler would be wise and you cant go wrong with EVGA G2 psu's
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($129.99 @ Amazon)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($59.99 @ Newegg)
Total: $189.98
Generated by PCPartPicker 2015-12-11 17:59 EST-0500
Ryzen Ram Guide
https://linustechtips.com/topic/502982-my-first-build/#findComment-6723461
