Wireless networking solution?
http://www.newegg.com/Product/Product.aspx?Item=N82E16833156321
Is this any good?
looking for a good usb wireless setup... rn I have a pci wlan card and it looks to ugly and ruins my build!
Intel i5 3570K || Gigabyte GeForce GTX 1070 8GB FE || 8GB Crucial Ballistix Sport 1600MHz || ASRock Z77 Pro 3 || WD Caviar Blue 1TB || Noctua NH-U12S || Creative Sound Blaster Audigy FX Sound Card || Fractal Define R4 || Gigabyte GC-WB867D-I REV 4.2 Wireless Network Card
ASUS VC239H Monitor || Corsair Strafe Cherry MX Red || Logitech G Pro || Philips SHP9500 w/ V-MODA BoomPro Mic || Reflex Lab Pro 36 Heavy Mouse Pad || Google Nexus 6P 128GB
https://linustechtips.com/topic/50270-wireless-networking-solution/
For not much more this has wireless AC which would bring better range and speed (router dependant; if you don't have an AC router now you probably will in the future) and looks much better.
I doubt it would give higher speed and longer range. Most people only have wireless n and a smaller device usually means smaller antenna which usually means less range.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
