confusing about Power Supply Unit
Go to solution Solved by dragoon20005,
I will suggest changing that PSU if it really old
the caps inside the PSU last at most 2 years
also those line of PSU are known to fail quite fast if you use too much power
and it not even a true 500 watts  PSU
Should be just fine
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Should be just fine
sorry bro
Extreme 2 like the Elite series and Thunder are the lower end PSU from Coolermaster
That'll do fine.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
sorry bro
Sure its a bit shit but it will still work
I wouldnt go out and buy one, and I would recommend replacing it, but it will still work just fine with his set up and a 950
oh...I will try to replace the psu as soon as possible...so can you tell me one more thing...what kind of "sign" I will have if the PSU is going to break...cuz I dont want this psu damage the rest of my pc.. :D
sudden power lost during gaming session
