I'm trying to copy a file, ard 700MB into my external harddrive via front usb 3.0 ports but i keep getting the message 0x80070079 "semaphore timeout period has expired". I tried to google for a solution but couldn't find a clear one so I'm here to seek help. Some said to use teh 2.0 ports instead but I want to avoid that since wouldn't that defeat the purpose of buying a 3.0 hard disk and a 3.0 case/mobo in the first place? Please help thanks
CPU: Intel i5 6500 Motherboard: Asus H170M-E D3 Memory: Kingston HyperX Fury DDR3 2x8 GB GPU: -NIL- SSD: Samsung 850 Evo 250GB HDD: HGST Deststar NAS 3TB Case: Corsair 240 Air Power Supply: Seasonic M12II Evo 620W Display: Dell U2515H 25" 2560x1440 Keyboard: Corsair Strafe (Red LED + Cherry MX Brown) Mouse: Logitech Performance MX Speaker: Edifier M1360 2.1
https://linustechtips.com/topic/502567-0x80070079-help/
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/502567-0x80070079-help/#findComment-6710230
thanks haha i actually found that too but i couldn't understand it :lol:  . so i basically have to unplug my usb devices one by one restarting the system each time?? like i don't really understand the steps
https://linustechtips.com/topic/502567-0x80070079-help/#findComment-6710315
I feel kinda dumb, I actually copied the wrong link over.
https://social.technet.microsoft.com/Forums/windows/en-US/c3fc9f5d-c073-4a9f-bb3d-b7bb8f893f78/error-0x80070079-the-semaphore-timeout-period-has-expired?forum=itprovistanetworking
That is the one I meant to link you.  It talks about sending stuff over WiFi, but it is the same error and should have the same resolution.
https://linustechtips.com/topic/502567-0x80070079-help/#findComment-6710447
