Quick Question on Frame Sync
I am interested in buying a 1080p 27-28" 60Hz 10ms TN panel.
My manifesto says that I won't upgrade monitor if I don't need to because if I don't know what I'm missing then I don't get caught in the money trap of constantly upgrading GPU's and displays.
I have never used an IPS or >60Hz or G-Sync or Free-Sync display before and I had a question for others that have never used those expensive monitors
Can you really tell that you're missing out on something if you have a TN display but have never used an IPS?
Do you feel like you're missing out on something if you don't have a frame-sync monitor but have never used one?
Is screen tearing that much of a problem if you are getting more than 60fps?
Would I be disappointed buying a 60Hz display if I have never used anything better?
I apologize about the horrendous formatting of my sentences. I need more caffeine.
https://linustechtips.com/topic/502044-quick-question-on-frame-sync/
I can never use a non-IPS display ever again - my eye strain is completely gone
For using a IPS screen over a TN you get
Much better colours and viewing angles as well as less eye strain
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
Well, it depends. Tearing is worse in some situations and some TN panels are shitty.
In my case, when I noticed that a spreadsheet that had a column in a single colour looked like it wasn't a single colour and when Linus got a mysterious tan because I slouched in my chair were moments when I started thinking about going IPS.
As for tearing, it can have a really obvious effect if you get a good scene where it occurs constantly on a short notice. For example, I noticed the shadow of a helicopter in a game was clipping consistently, which was really awkward. A less consistent case of tearing can make it feel like your TV is dying or you're getting a "bad signal" on the game.
I own and use, sorted from newest to oldest: SteelSeries 6Gv2. Microsoft SideWinder X4. Mionix Naos 7000. Zowie EC1 Evo. Microsoft SideWinder X8. Microsoft IntelliMouse Explorer 3.0. Dell U2414H. Samsung P2270H. AKG K273 Pro. Sennheiser HD555. Razer Goliathus Speed Medium. Func 1030 L. Qpad CT Medium.
I used to own: Razer DeathAdder 3G. Razer Krait. IntelliMouse Optical 1.1. SteelSeries QcK.
