I need an 8pin extension for my cpu power, are the any differences between extension cables ? if yes, got any recommendations?
I know hella random question but anyway lel
As long as they are atleast 18AWG (wire size) your good, if you want sleeved extensions bitfenix, or silverstone makes some good ones.
https://linustechtips.com/topic/501673-8-pin-extension/#findComment-6698088
Oh, another question, is there a difference between a PCI-E one and the CPU one?
Yes. The pin-outs are different.
https://linustechtips.com/topic/501673-8-pin-extension/#findComment-6698163
