If a power supply spins your CPU fan upon turning on the power switch (without pressing the on button) even without the front IO connected to the motherboard
And that a fully working GPU doesnt output a display
Is it a dead powersupply? Or a dead CPU/Mobo?
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/501406-possible-dead-psu/
It is very hard to diagnose a hardware problem over the internet.
I'd test the ram dim by dim, and running off iGPU, if all ram passes, test the GPU.
If the GPU fails on that board, test it on another motherboard.
The problem is the CPU fan spins with NO RAM LOL
There isnt an iGPU
It's an athlon ll (x2 or x4 im not sure) on a MSI 870-C45
GPU is already tested on my main rig and it works
https://linustechtips.com/topic/501406-possible-dead-psu/#findComment-6694550
There isnt an iGPU
Test with a different PSU, test the ram and unplug everything but the ram, GPU and power supply.
https://linustechtips.com/topic/501406-possible-dead-psu/#findComment-6694556
If the psu was dead, it wouldn't work.
You have to check it with integrated gpu or with another graph card.
Also, it's really bad that nobody today has a speaker on the mobo, so it would be easier to recognize a problem.
Most likely for now, the mobo is dead.
https://linustechtips.com/topic/501406-possible-dead-psu/#findComment-6694606
Hmmmm but if it's a dead mobo would the CPU fan even spin up?
I dont really have another PSU on hand and the one i have in my PC is all cable tied up xD
https://linustechtips.com/topic/501406-possible-dead-psu/#findComment-6694629
