White? No idea. But for an awesome liquid cooling case, look up the Core V21.
Systems built (personal) | 1. Bad Wolf (Has passed on to PC Heaven): https://ca.pcpartpicker.com/b/zX9WGX |  2. Red Husky: https://ca.pcpartpicker.com/b/Mwhypg
Systems built (for commission) | 1. Red Fox: http://ca.pcpartpicker.com/b/W4LD4D | 2. Not Namedhttp://ca.pcpartpicker.com/b/TMhqqs 3. Bad Wolf 2.0: https://ca.pcpartpicker.com/b/7p8Ycf upgraded Bad Wolf to an I3-7100 for my friend as a gift|
http://www.phanteksusa.com/products/phanteks-enthoo-primo-white
I have the black and green myself have two 480 rads and a 240
Cooling my 2 980tis and 5930k
Lots of room comes with one PWM hub and build in switch for lighting
http://imgur.com/qtK18vd
http://imgur.com/GJzwETF
My cooler master haf xb evo is good, it can house my EKWB sp 240 rad and 140 x series reservoir without any problelem. (You will need 3x 90 degree fittings and atleast 1x 45 degree fitting depending on reservoir placement and how well the top radiator outlet lines up with your top reservoir port.)
My pc:
http://pcpartpicker.com/p/dvcw23
(Black Glacier)
My server:
Dual xeon x5679 processors, 24gb of ECC memory, Nvidia quadro 295 NVS and 48tb of storage.  (z600
