Case Help!
Go to solution Solved by Gidoguy,
I'm building a new gaming pc to replace my aging one and I cant decide on which to pick i've narrowed it down to three sub 100 dollar cases the Corsair 230t , CoolerMaster N600 and Bitfenix Ronin so I want your opinion. :)
I would recommend the Phanteks Enthoo Pro M. Much better build quality, better cable management, dust filters and much more internal space in the motherboard area as hard drives, your psu and its cables are kept in the lower compartment. Its also a lot more future proof as it has ample space for a 280mm radiator, liquid cooling pumps and a lot of storage options in terms of ssd and hdd bays. The only problem is you will have to buy an extra case fan for the front. A decent 140mm static pressure fan will run you about $15. But its definitely worth it.
HardwareCanucks revew -
Δ Ambassador for the Illuminati Δ
Δ "Illuminati confirmed" - Nobody  Δ
https://linustechtips.com/topic/501154-case-help/#findComment-6694235
Bitenix Ronin
Bitfenix Ronin all day.
A very elegant case, it just lacks a compartment for the PSU. I don't want to see that thing in there, it ruins the magic.
Eien nante naito iikitte shimattar  /  Amarinimo sabishikute setsunai deshou
Dare mo ga hontou wa shinjitai kedo  /  Uragirarere ba fukaku kizu tsuite shimau mono
https://linustechtips.com/topic/501154-case-help/#findComment-6694250
I checked the prices on amazon of the black version and 2 bitfenix spectre fans and It came to $150 way to much but thank you anyway
https://linustechtips.com/topic/501154-case-help/#findComment-6699065
