Would anyone not mind holding my hand through this process and answering a lot of questions please?  :mellow:
So... I would like to water cool my gpu... and only the gpu... I believe that this wont really be worth it considering how much this will cost to do just that and the benefits aren't that great for the costs, but I am still interested in water cooling my gpu
The two parts so far I know I would get, and I would get the rest of the parts I need from ekwb
Block - https://shop.ekwb.com/ek-fc780-gtx-classy-acetal-nickel
Radiator - https://shop.ekwb.com/ek-coolstream-xe-240-double
Beyond knowing what block and maybe radiator I need to get, I dont know if I should get a pump and reservoir that are assembled together or to just get each part individually
I also dont know what size soft tubing and fittings and how much of each to get
And I also dont know anything about maintaining this loop if I manage to get everything going, I want to believe that since its only 1 loop for the gpu the typical time that one would wait to replace the water in the loop could be longer or is that a very wrong assumption.
Also is it an easier time to set up a gpu loop in comparison to a cpu loop and doing the leak tests and other stuff I would have to do for this loop to be successful?
And if a gpu loop were too leak, I want to assume depending on where the other parts are, could the whole system not be at risk of being destroyed by the leak?
I apologize since these questions are answered in the water cooling faq topics, I did look at them... but I dont know.... I just still have questions to ask. Sorry.
I would really like to try and do this, but if it really is pointless... should I just fuck off.  :(
https://linustechtips.com/topic/500995-water-cooling-beginner-help/
Hey, NZXT sells an All-in-one closed loop cooler for gpu's.
https://www.nzxt.com/products/kraken-g10-white
Current Build: Core i7 4790k @ 4.6, Asus Maximus VII Hero, Corsair Vengeance Pro 2400mhz 8gb (2x4gb), GTX 980ti, NZXT Kraken X61, Fractal Define R5  EVGA Supernova B2 850w, Some 300gb hard drive.
http://pcpartpicker.com/p/W7CNrH
Do it because it's a fun project and because it looks cool, not because the performance gains will be worth the cost (they won't be). If you sink the costs into the pump, res, fittings, might as well add the cpu to the loop. Pump res combos are easier and more cost effective, though choice is reduced. expandable AIOs or Custom kits offer even better value for money. Size of tubing doesn't matter, except for aesthetics, and maybe bend radius. Fittings for soft tube are barbed and compression fittings. They both work fine, barbed are cheaper but uglier. Match the size of the tube to the size of the fittings. Replace distilled water every 1/2 year or so, same for gpu loop and cpu loop. If you add a coolant, check the reccommendation on the packaging. try to build in a way of draining the loop (desirable but not required). Same leak tests, (though gpu block is more difficult to install than cpu block), I'd still put the pump on the power fan header if you have one. Leaking water kills anything it touches.
If you make a post contradicting mine that doesn't directly address my claims, or cites 'facts' without evidence, I'm probably not going to bother responding to it, because you probably didn't bother reading my post properly, and because life is too short. It doesn't mean I don't have an answer for you. It means I'm not dignifying you with a response.
  • 3 weeks later...
I would like to make a purchase within the next two days, could anyone lmk if these things are everything I need to set up a wc set
https://shop.ekwb.com/tube-primochill-primoflextm-advanced-lrttm-12-7-9-5mm-crystal-clear-retail-3m
https://shop.ekwb.com/ek-xres-140-revo-d5-pwm-incl-pump
https://shop.ekwb.com/ek-ekoolant-evo-clear-premix-1l
https://shop.ekwb.com/fittings/compression-fittings/for-10-13mm-3-8-1-2-tubing - How many fittings do I need to get in a gpu only set up? 4? or is it only 2 I need?
Also for this thing below, Are these the things I need to be looking at to do this
Get a no spill quick disconnect. These cost around £10-20 for the complete set and click into each other. You can cleanly separate the loop. You can split a tube in half with almost no water spillage. These add some restriction to the loop but now-a-days have been improved a lot so this restriction is minimized.
What part do I need to get from ekwb to be able to do this?
https://shop.ekwb.com/fittings/extra/splitters
https://shop.ekwb.com/fittings/extra/ball-valves
Can someone help me out with a loop question, is there a specific loop set up i need to set my loop in or can i set it up like this, the out and in thing is what it says on the reservoir with out being on the left and in being on the right, is this important with how i need to be setting my loop up
ietV15B.jpg?2
The end result, question about leaving the loop on for 24 hrs, i guess i leave the pin in the 24pin and the psu on for that time right? and is it a must that i need to leave it on for 24 hrs or can i cheat on the time and stop at 18 - 20 hrs, i understand the necessity in testing it for that long, i just wanted to ask is all
hGLx8kX.jpg?1
