I am looking to get my A8 6600K to 5Ghz, its at 4.9ghz right now. Don't worry about the psu, or airflow, or motherboard, those are good and not something that need to be worried, its thermal margin is about 10C under full load at 1.49v although it never gets that hot during gaming which is the most cpu intense task I do currently, I am wondering what would improvement I would see on my HSF if I replaced the stock fans on it with a single Delta AFB1212GHE running at full RPM. My HSF is a Phantek TCDX12.
https://linustechtips.com/topic/500337-going-for-5ghz/
10C? Is there a zero missing form that?
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/500337-going-for-5ghz/#findComment-6681442
wow i didnt know that was a thing you could do on an apu
I got my A10 to 5 Ghz. But that was on linux so I couldn't tell if it was stable or not. and it was on the stock cooler. I don't even know what I did back then.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/500337-going-for-5ghz/#findComment-6681452
Thermal margin dictates how far away it is from hitting TJ Max.
https://linustechtips.com/topic/500337-going-for-5ghz/#findComment-6681456
Oops, I can't read.
https://linustechtips.com/topic/500337-going-for-5ghz/#findComment-6681465
