Hey guys, I've just purchased a pair of HyperX Cloud II from amazon on cyber Monday and I've experienced a few problems in audio quality. If you don't know already it comes with its own "sound card" that ends in a usb and whenever I am using it voices on teamspeak sound completely different from using the jack directly. I have also noticed crackling and popping when using the soundcard provided, has anybody else encountered these issues?
https://linustechtips.com/topic/500140-hyperx-cloud-ii-problems/
I have experienced a bit of crackling but only once every few days for a couple seconds thats all. Other than that and the slightly degraded mic quality im lovin the cloud IIs  :D
CPU Intel Core i5 6600k @ 3.5GHz GPU MSI Radeon R9 380 4GB Motherboard Asus Z170 Pro Gaming RAM Kingston Fury 2x4GB DDR4 2666MHz PSU XFX 650W Storage Seagate 1TB, WD Blue 1TB, Kingston 128GB SSD OS Windows 10
https://linustechtips.com/topic/500140-hyperx-cloud-ii-problems/#findComment-6679219
It's not as bad if I don't touch the 7.1 button I have noticed, the mic isn't an issue as I use my condenser
https://linustechtips.com/topic/500140-hyperx-cloud-ii-problems/#findComment-6679234
