You either need to pick up a couple splitters or a fan controller with room for 5 fans. Using splitters would be the much cheaper option, but you need to make sure that you don't have more than 2 fans using a single motherboard fan header.
http://www.newegg.com/Product/Product.aspx?Item=9SIA25V22N9912&cm_re=fan_splitter_cable-_-9SIA25V22N9912-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16811992012&cm_re=fan_controller-_-11-992-012-_-Product
Quote
Ignis (Primary rig)
CPU
 i7-4770K                               Displays Dell U2312HM + 2x Asus VH236H
MB ASRock Z87M Extreme4      Keyboard Rosewill K85 RGB BR
RAM G.Skill Ripjaws X 16GB      Mouse Razer DeathAdder
GPU XFX RX 5700XT                    Headset V-Moda Crossfade LP2
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Storage PNY CS900 120GB (OS) + WD Blue 1TB
Quote
Server 01Alpha                                       Server 01Beta                            Chaos Box (Loaner Rig)                Router (pfSense)
CPU
 Xeon X5650                                      CPU 2x Xeon E5520                    CPU Xeon E3-1240V2                     CPU Xeon E3-1246V3
MB Asus P6T WS Pro                               MB EVGA SR-2                             MB ASRock H61MV-ITX                 MB ASRock H81 Pro BTC
RAM Kingston unbuffered ECC 24GB  RAM G.Skill Ripjaws 16GB         RAM Random Ebay RAM 12GB    RAM G.Skill Ripjaws 8GB
GPU XFX R5 220                                       GPU EVGA GTX 580 SC               GPU Gigabyte R9 295x2                GPU integrated
PSU Corsair CX430M                               PSU Corsair AX1200                   PSU Corsair GS700                         PSU Antec EA-380D
Case Norco RPC-450B 4U                      Case Rosewill  RSV-L4000C        Case Modified Bitfenix Prodigy   Case Norco RPC-250 2U
Cooling Noctua NH-U9S                        Cooling 2x CM Hyper 212 Evo  Cooling EVGA CLC 120mm           Cooling stock
Storage PNY CS900 120GB (OS)           Storage null                                 Storage PNY CS900 120GB (OS)  Storage Fujitsu 150GB HDD
               8x WD Red 1TB in Raid 6        WD Black 1TB
               WD Green 2TB
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671853
So all the case fan wires connect to the fan controller and just need like one wire which connects them all.
The splitter wire dosent look long enough.
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671865
Only way to power case fans are on the motherboard?
I have a b85 pro4 and apparently I can only fit case fans. Not so sure though...
What happens if I have a case that supports 5 case fans but my motherboard only allows 2-3 :(
Hard to think of a good title
Fan question would be a good title as well.  If your temps are fine, don't worry about it.  Otherwise, what
said, except you can have a smaller fan controller and use the mobo fan headers too.  It's just that the fan controller won't be able to control the mobo connected fans.
- Pete
Folding For Linus since July 2015
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671871
- Pete
My CPU stock cooler runs over 2000rpm....I swear like 2600rpm and runs at 70'+
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671875
It doesn't take much to improve on a stock cooler - might want to consider just upgrading that first, and if that doesn't cut it then consider upgrading your case fans. ;)
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671895
I only have 1 crappy case fan though. Upgrading my case
What case do you have and why do you feel that you need more fans? If it is a CPU temp issue then as stated before you would see a huge improvement by ditching the stock cooler and getting an aftermarket one.
Edit - I see your specs on your profile, from the looks of it you can only install one fan your case anyway, unless you wanted to get creative, but even then there probably wouldn't be too much improvement in airflow.
4790k @ 4.5Ghz 1.180v NZXT Kraken X31 | MSI Z97 Krait | Kingston Hyper X Fury 32GB 1866Mhz, 2 DIMMs white and 2 black | GTX 980 Ti - G1 Gaming | GTX 680 - Reference | SilverStone ST75F-P | Phanteks Enthoo Pro
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671970
Upgrading to corsair spec 03
(Random question) on fan controllers why the **** does it have the temperature for each one. Is the temoerature showing what? The fan?
Everything needs to be cooled like the gpu and for future improvement and everything needs to be cooled
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671987
U have 3 PC and all these puerile also and your in AU. SOOOOO RICH
https://linustechtips.com/topic/499432-fan-placement/#findComment-6671998
(Random question) on fan controllers why the **** does it have the temperature for each one. Is the temperature showing what? The fan?
So you currently have two fans then, the one that came with your old case and the one the came you your new Corsair case? You don't really need more than 2 in most situations.
I don't get what you mean, I don't really diddle around with fan controllers but I haven't seen any temperature readings from mine.
Your Pentium and 750 Ti won't really kick out much heat so you really won't have a problem. I'm serious not needing to worry about the G3258 cooling, for a few weeks I had mine passively cooled while OCed to 4Ghz and it sat around about 65 degrees under load, although it was with a NH-D14 but still, it doesn't take much to cool low end chips.
Haha not really, I just saved up for a while for my main PC and then put a couple hundred into used parts for my folding PC, secondary PC is just some old parts thrown together for my room mate to use.
https://linustechtips.com/topic/499432-fan-placement/#findComment-6672035
Just use splitters and connect the Fans to the PSU. There will be no rpm Controll, but who need that anyway?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/499432-fan-placement/#findComment-6672054
I don't have the corsair spec 03 yet
What plug does the fan controller have that uses it to connect in the motherboard.
https://linustechtips.com/topic/499432-fan-placement/#findComment-6672065
Make the CPU case fans cooler. It's good to have it. I found one for $10
CPU Case Fan?
https://linustechtips.com/topic/499432-fan-placement/#findComment-6672071
A fan controller just plugs into a fan header as if it was a fan, you then power it from your PSU usually from a molex or SATA power. The manual that comes with it should explain it all to you, might even have some pictures to give you a visual representation. Also just saying in case you weren't sure, your CPU fan should always be plugged into the fan header marked CPU_Fan on your motherboard.
https://linustechtips.com/topic/499432-fan-placement/#findComment-6672090
With the fan controller, everything you need should be included.
There are longer splitter wires available, better looking ones too, I just went with the most inexpensive one I could find. I didn't think you wanted to spend like $10 on a single cable.
Quote
Ignis (Primary rig)
CPU
PSU Lepa G1600
Case Corsair 350D
Cooling Corsair H90
Quote
CPU
               WD Green 2TB
https://linustechtips.com/topic/499432-fan-placement/#findComment-6672320
