Rm850x Cable question.
Go to solution Solved by Gidoguy,
... Nvm if have actually PSU you would know want I mean or you have done some research.
I know exactly what I'm talking about, heres a picture to help you explain what I'm on about.
I have recently got RM850x PSU and while i was looking through i the cable i see it has two 6+2pin in one cable, so i was wondering is safe running it off just one cable for MSI 980ti or should i use two and just use one of 6+2pin for each cable. The reason i ask this because the cable is quite stiff and it really hard to cable mange this is use two cables.
Build Log:
http://linustechtips.com/main/topic/494416-tuf-silent-r5-build-log-amd-to-intel/?view=findpost&p=6618334
Magical Pineapples
https://linustechtips.com/topic/499384-rm850x-cable-question/
The RM850X will be able to run that GPU comfortably, it should also come with all appropriate cables for supporting that kind of hardware.
I know that... But could 2 8pin run off one cable... To PSU
Magical Pineapples
https://linustechtips.com/topic/499384-rm850x-cable-question/#findComment-6671848
I don't understand, the two 2+4 pin GPU power cable will be compatible with and power all graphics cards on the market, just connect all the power cables that the 980ti needs, it should say in the manuals of your psu and gpu, they really help sometimes.
Δ Ambassador for the Illuminati Δ
Δ "Illuminati confirmed" - Nobody  Δ
https://linustechtips.com/topic/499384-rm850x-cable-question/#findComment-6671877
Magical Pineapples
https://linustechtips.com/topic/499384-rm850x-cable-question/#findComment-6671884
https://linustechtips.com/topic/499384-rm850x-cable-question/#findComment-6671930
Ah kk. So it ok
Magical Pineapples
https://linustechtips.com/topic/499384-rm850x-cable-question/#findComment-6671935
Plz choose best answer, thanks :)
Sure... When I'm on a PC. Currently using tapatalk
Magical Pineapples
https://linustechtips.com/topic/499384-rm850x-cable-question/#findComment-6671954
