So I'm new to the Water Cooling side of things, currently using a Dark Rock Pro 3 and it's splendid, but it takes up a little too much room and I personally would prefer a smaller yet sexy and effective look. Therefore, I came to water cooling. I doubt I'd be creating my own custom loop for a while so I was going to stick to a standard AIO cooler. Possibly an expandable one but I'm not too fussed, if there is one in my range then sure, might as well in case I want to include my 980 ti at some point.
So as you can probably tell, aesthetics mean a lot to me, and so I'd like an AIO that is either sealed or expandable that's roughly 240mm and if it comes with fans, then also let me know if they're any good or not and suggest some <3 (Like I said, the look means a lot to a person like me so please don't reference Noctua fans that are covered in brown because... Yuk xD) The price range isn't too bad because I won't be getting it for a while and can probably save up quite a bit. I've heard that the H-220-X is a good one but some say that the Reservoir cracks easily and so I'm not leaning towards that one, others say that the EK Predator 240 is a good.
Point being, I'm looking for opinions on AIO coolers and if possible some suggestions. I'd say the max price is £150-£200 if it really impresses me <3
-Thank you
  vK <3
https://linustechtips.com/topic/498911-aio-cooler/
