My friend was complaining about Random BSODS, so after looking at the minidump in WinDBG, I noticed that Avira's Scanning Component was causing the system to sometimes crash.
Looking in the Event Log, I noticed an irregular pattern of crashes and decided that I would run the system file checker and run Memtest86 to be thorough.
I received the following errors after running memtest:
I get the same errors using both the original DIMM and a known good DIMM in both slots on the motherboard.
More details can be provided if requested, but I am currently at work so if you would like the exact motherboard model, I will provide it some point later on today.
Thanks for any help provided!
https://linustechtips.com/topic/498790-memtest86-same-errors-different-dimms/
Try his ram in another pc, if it passes memtest then the problem is most likely with the ram slots/memory controller
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
