Fan Placement Question
Solved by dankarlo,
They're basically the same fan but rated for different speeds.
What case are you using and what are you cooling?
Have you tried lowering fan speeds to minimize noise?
You need to quote a post or tag a member or else they won't get a notification you replied to them.
Thanks. I'v resolved this. i put it in one of the front intakes and lowered the rmp tp 800. I tested the noise level with Sound Meter and it is around 26dB from 1m distance which is good. I can only hear the soft wooosh of the fans ![]()
