I've been attempting to install this graphics card for over a week to replace the current GTX 550 ti. Even swapping to a new power supply. I don't want replace the motherboard  to but i think the it may be to old for the card perhaps the DDR5 v-ram on the card is clashing with the ga-b75m-d3h and CPU  support for DDR3. I dont know please help.
Motherboard: ga-b75m-d3h
CPU: Intel Core i7‑3770 3.4 GHz Quad‑Core
Power supply: EVGA SuperNOVA 850 B2
Ram:4x 4gb  Chinese DDR3
with the card installed the monitor is at black screen.
https://linustechtips.com/topic/498492-strix-r9-390-upgrade-problems/
It should work. is the card inserted properly and is the power connectors plugged in right?
CPU: AMD R7 5800X | CPU Cooler: Corsair H115i PRO | Motherboard: MSI B550-A PRO | Memory: G.Skill RIPJAWS V DDR4 3200mhz 64GB | GPU: EVGA RTX 3080Ti FTW3 Ultra | PSU: Seasonic Prime 1300w | OS Drive: Samsung 850 EVO SSD 500GB | Games Drive: Samsung 850 EVO SSD 1TB | Media Drive: 2x WD Blue HDD 1TB in Raid 0 | Media Drive: 2x WD Black HDD 2TB in Raid 1 | Case: Corsair Obsidian 750D | Monitor 1: ASUS PB287Q UHD | Monitor 2: ASUS PG278Q WQHD
Are your display cables plugged int the GPU?
You might have to disable iGPU.
yes 8 and 6 pin and even put the PC on its side to make shure
Do tell. must i plug in a spare monitor to the motherboard wile i boot the PC to select the new card or somthing like that?
Usually, you should be able to plug the GPU in, plug your display cables into the GPU and be on your way.
You might have to enable/disable something called iGPU Multi Monitor in your BIOS and you might have to change a setting that says something similar to Onboard video to PCIe.
