Basically I made a post before and then went back and checking my compute with different GFX cards and found out my EVGA GTX 960 SSC was faulty after about 5-10m my screen goes and says "no sinal" and I'm looking for a fix if I turn my computer off then on it works for 5-10m again so on and so forth please reply if you low how to fix!!!
https://linustechtips.com/topic/498420-graphics-needs-fixing/
RMA and get a R9 380
https://linustechtips.com/topic/498420-graphics-needs-fixing/#findComment-6660992
Try a different cable or try a different output from the card. If neither of those do anything different try it with a different monitor/tv is possible. If you can't then you might just want to go ahead and contact EVGA so they can help you troubleshoot the card or setup an RMA to get the card replaced.
"The of and to a in is I that it for you was with on as have but be they"
https://linustechtips.com/topic/498420-graphics-needs-fixing/#findComment-6661022
It may be your PSU theoretically. Abrupt shutdowns result from the components not getting enough power. I had that happen to me playing Dead Space on my old rig several times. It turns out, the PSU was dead and i had to salvage one from a different PC.
https://linustechtips.com/topic/498420-graphics-needs-fixing/#findComment-6661184
Yea ok but now I get maybe 15m in a just cause three before it does that no sinal thing again any ideas?
https://linustechtips.com/topic/498420-graphics-needs-fixing/#findComment-6666315
