Do i have enough power?
Go to solution Solved by BuntzenB,
Ok i will look at it and find the right one. tnx
Basically what everyone is saying. You are fine on the wattage, but it would do you well to get a higher quality psu, (and an 80+ silver or better while youre at it)
Hi,
Im building my pc but i dont know if the psu i want to buy has enough power for my pc.
sorry for my bad english> :unsure:
And is it enough for future upgrades?
       CPU f6776a85afe4c2236d84eb42fe6da169.med.256
$219.99
Motherboard 61f8ff960037cd1b618eb3d5d461f05b.med.256
$124.99
              Video Card eaa072ab396eb9de47b15bd924720a02.med.256
$348.99 -
    Add Another Video Card For 2-Way SLI   Case 4dece31029b24798177b7e0c7e23766a.med.256
$139.99
  Power Supply 76df2da5f803e2bae5708c3049ab6875.med.256
https://linustechtips.com/topic/497751-do-i-have-enough-power/
Use PCPartPicker next time,
Good processor,
Good motherboard
You'd be better off with a 390
The case is fine, because it's a matter of preference
And for such a high-end build, please don't go with a CX600M. CX-series power supplies are of poor quality compared to others.
https://linustechtips.com/topic/497751-do-i-have-enough-power/#findComment-6652597
get a better psu tier 1 or 2
RIG #14670k @4.4 / 1.25v vcore. @ 4.5 / 1.3v vcore/ 1.95v vccin. MSI GAMING 4G GTX 970 @1540/3700 1.275v BIOS MOD. 16GB Kingston HyperX Savage RAM 2400mhz. MSI GAMING 5 Z97 MOBOFractal Design Define S. Dark Rock Pro 3. 850 EVO 250GB Seasonic M12II 620w
RIG #2: 4790k @ 4.6 / 1.25v vcore. EVGA SC ACX 2.0 980 SLI16GB Corsair Vengeance Pro 2400mhz. Asus MAXIMUS VII Hero Z97. Fractal Design Define R5. NH D15. 850 EVO 250GB AX 860
https://linustechtips.com/topic/497751-do-i-have-enough-power/#findComment-6652652
Good processor,
Good motherboard
Do you have a opinion for a psu?
https://linustechtips.com/topic/497751-do-i-have-enough-power/#findComment-6652661
What does that mean :wacko:
http://linustechtips.com/main/topic/406160-psu-ranking-and-tiers/ look at the tier 1 or 2 they are quality psus. find the cheapest one possible if your on a budget
https://linustechtips.com/topic/497751-do-i-have-enough-power/#findComment-6652672
