https://linustechtips.com/topic/497713-pc-monitior-help/
Forget the ASUS monitor.
The LG comes with a higher refresh rate and at a much lower price and has also a 99% sRGB color accuracy.
The only advantage of the ASUS monitor is that it is hight adjustable, has pivot and swivel. But for the money you safe you can easily buy a new stand for the LG monitor and mount it to the VESA mount.
https://linustechtips.com/topic/497713-pc-monitior-help/#findComment-6652151
Thank you
Can I get a wall mount for it.
https://linustechtips.com/topic/497713-pc-monitior-help/#findComment-6652160
Thank you
Since it has a VESA mount there will be tons of options to mount it. And yes it will be able to be wallmounted then.
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
https://linustechtips.com/topic/497713-pc-monitior-help/#findComment-6652705
