295x2 crossfire help.
Go to solution Solved by App4that,
Yes, Fullscreen windowed.
Go to just full screen. Sometimes being in any form of windowed disables the second GPU. I had that issue with Witcher 3.
I have ulps off, Im using a crossfire profile for the game im playing (star wars the old republic) yet it only uses 1gpu, even when its maxxed at 100% usage and a bit laggy the other gpu wont kick in, or if it does wont go past 15%.
How can I fix this? Any help is appreciated
CPU -  Intel i7 4770k 4.6Ghz     Motherboard - MSI GD-65    RAM - Corsair Vengeance 16 GB     GPU - XFX 295x2    Case - NZXT H440
Storage - 256GB OCZ Vertex 4 ssd, 1TB WD Blue 7200rpm    PSU -  EVGA SuperNOVA 850 G2  Cooling - Corsair H80i     Keyboard - KGParadise v60 w/ cherry mx greens
Mouse -Theron  Sound - HyperX Cloud
https://linustechtips.com/topic/497573-295x2-crossfire-help/
The old Star Wars game probably doesn't support CrossFire. Most older games don't support more than one gpu.....
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/497573-295x2-crossfire-help/#findComment-6650634
Are you sure that it's just not the game? Some games (very few) may not use xfire, especially older games.
Star Citizen referral codes, to help support your fellow comrades!
UOLTT Discord server, come on over and chat!
i7 4790k/ Bequiet Pure Rock/Asrock h97 PRO4/ 8 GB Crucial TT/ Corsair RM 750/ H-440 Custom/  PNY GT 610
Damn you're like a modular human being. -ThatCoolBlueKidd
https://linustechtips.com/topic/497573-295x2-crossfire-help/#findComment-6650636
Everything I've read said it supports crossfire. Could be wrong though.
https://linustechtips.com/topic/497573-295x2-crossfire-help/#findComment-6650665
Are you in windowed mode?
https://linustechtips.com/topic/497573-295x2-crossfire-help/#findComment-6650704
Thank you! Will try it out, never thought of doing that.
https://linustechtips.com/topic/497573-295x2-crossfire-help/#findComment-6650719
